How to Properly Disassemble and Clean a Unisaw
Written by Keith Bohn December 27 2007 {Reference:http://owwm.org/viewtopic.php?t=32049|http://owwm.org/viewtopic.php?t=32049}. Quote "In reality you could dismantle and clean a Unisaw and have it all back together over a good weekend."
The pictures in this wiki are of a 1953 Unisaw disassembly, and were provided courtesy of Joe Wells{Reference:http://www.joewells.org/owwm/Unisaw|http://www.joewells.org/owwm/Unisaw}. They were not taken specifically for this wiki, but fit (mostly) pretty well. Larger photos are available on Joe's website.)
If you are a first time restorer of woodworking machines you might want to read the Restoration Guide and the Electrolysis Guide
Preparation
The Tools You Will Need
  • Hammer
  • Set of Pin Punches
  • Screwdrivers (note plural)
  • Socket Set
  • Combination Wrenches
  • Straight Razor and Holder (Handle)
  • Scotch Bright Pads (Coarse to Medium)
  • WD-40
  • Marvel Oil or Preferred Equivalent
  • Parts Tubs (you can use cheap plastic shoe boxes or any container for this)
  • Baggies (small sandwich size to large)
  • Air Compressor
  • Shop Vac
  • Awl(s)
  • Wire Brush
  • Bench Brush (optional)
  • Dead Blow or Rubber Mallet
Remove the Top
Yank Out the Guts
Your next step is to take pictures. Take lots of pictures and while you are at it go to the Old WoodWorking Machines Web page and download a parts drawing for your vintage. I like to take parts drawings and enlarge them at the copy machine at work (of course) and make several copies of each page. I use these in conjunction with a high lighter and make pages specifically for each of the major assemblies. That way I can clearly see what it is I’m working on and not be distracted by all the other parts. I also use parts drawings from different eras and actually sometimes prefer the newer drawings as they might show how parts are arraigned better than the older drawings.
Splitter Bracket
Splitter Bracket
Splitter Bracket Removed
Blade Tilting Hand Wheel
Motor Off
Motor Off
"Smile"
Dust Deflector
Dust Deflector
Now we’re getting serious and about to go beyond the point of no return. There are two different approaches to removing the internal guts of a unisaw. One approach is to remove the tilt shaft while everything is still inside the cabinet, which frees up the tight fitting connections between all the major components and enables you to lift them straight out. The other approach removes the major components intact for further disassembly on your bench. Yes, believe it or not you can remove the entire guts of the saw with minor disassembly. I know because I did it. The shafts on my saw were so buggered up and grimy that I just couldn’t remove them to facilitate an easier disassembly. For the record, the doing of this (removal with little disassembly) was as close to child birth as I will ever get, and despite the fact that the official hat of the club of those of us that have done it is the dunce cap, we are a proud bunch.
Some people find that it's easier to use the first approach where you remove the shafts by popping out the pins, with the castings still installed inside the cabinet. Others find the second approach easier and faster by pulling the castings and taking them to the bench to drive out the pins. In some cases, folks may not even remove the pins to take apart the assemblies, choosing instead to just tape them off before painting. Over time, we've come to see that pulling the guts intact is not as daunting as it seems at first, and many folks use this approach as the first option rather than as a fallback. A primary consideration of which approach to use is how much fight the taper pins give you when you first go to drive them out. Some have been known to come out with a few good solid raps with a well placed punch and deadblow hammer. Others have been known to fight back with a ferocity that makes a sledge hammer shudder. If you are trying the first approach and your taper pins are putting up a good fight, it's probably a good idea to change approaches rather than to grab a bigger hammer and whack on it even harder.
Approach 1: Removing the guts by pulling the blade raising and blade tilting shafts first.
Now the real fun begins. Inspect the two shafts used for blade raising and blade tilting. These need to be removed but it’s very important that you follow the procedure. Don’t Ask Me How I Know This. If the shafts are the least bit grimy, clean them. Lube the shafts using WD-40 and start scrubbing with a coarse Scotch Bright pad. Get them clean. Shiny is not required. Next inspect the shafts for any buggering (raised metal) and file away the high spots with a fine metal file.
Height Adjustment Shaft
If prying is unsuccessful at removing the Arbor Bracket, instead you can use a gear puller with two claws on it. The end of the motor bracket shaft doesn't have a center dimple, so to keep the point on the puller from digging an ugly off-center dimple in the shaft, I put a 1/4" nut between the end of the shaft and the puller.
Pulling arbor instead of prying
Arbor Assembly Removed
Trunnion Assembly Removed
All Apart!
All Apart!
Approach 2: Removing the guts leaving the major components assembled.
If you find that it is particularly difficult to pull the main shafts for some reason, an alternative approach for removing the guts is to pull the main component assemblies out of the cabinet intact and do the further disassembly on your bench. Here is how you do it, noting that it is not as straightforward in real life as it appears here in print.
These photos are taken from the front of the saw, with the manual labor occuring in back.
Step 1. Preparation. Remove all exterior parts and bracket mounting bolts as described in various instructions above. Remove the arbor bracket as described above and tilt the arbor a fair bit. Push all of the components as tightly to the front of the cabinet as possible. Don't forget to remove the guide block on the bottom of the gears.
Starting point
Starting point
Remove the guide block
Step 2. Remove the rear trunnion bracket. Gently wiggle the rear of the yoke and the rear trunnion bracket apart, to the point where the half-moons of the two pieces disengage. You may need to lift the yoke assembly a few inches to provide clearance above the edge of the cabinet for the rear bracket to disengage completely and slide out. Note that the yoke should not fall off the front trunnion if you happen to let go of it for a moment after removing the rear bracket, but that is neither recommended nor encouraged.
Separate the rear trunnion bracket from the yoke
Lift the connection slightly
Lift the rear trunnion bracket out
Step 3. Remove the yoke. This is the (in)famous drop/twist/rotate/lift all-at-one-time move. That's literally what you do. It helps to have a second pair of hands. First pull the yoke towards the rear of the cabinet to disengage the half-moons from the front trunnion. Then, bearing the full weight of the yoke, drop the front end down, twist the yoke so that the gear teeth come up towards the side, rotate the entire assembly as much as possible diagonally across the cabinet. Curse at it a couple times, look to see how much further you need to go for the shaft to clear the cabinet, and wrestle it on out. Nicely done.
Separate the yoke from the front trunnion bracket
Drop the front end of the yoke
Twist, rotate, and lift the yoke out
Step 4. Remove the front trunnion bracket. Now that the heavy lifting is done, the front bracket comes out easily. Gently ease it to the side and rear so that the shaft clears the cabinet, and lift it out.
Note that this photo is taken from the right rear of the cabinet, not the front.
Pull the front trunnion bracket out
Step 5. Relax and smile. Enjoy the fact that you just got those things out of there and realize that in a few days/weeks/months you'll need to reverse the process to put them back in just so. Here is what they will look like sitting in your shop at this point.
Unisaw guts removed intact
Disassmble the Subassemblies
Trunnion Disassembled
Base Removed
Base Removed
Cleaning and Replacing Worn Parts
At this moment you should strongly consider replacing the arbor bearings. This can be done by you with the aid of an arbor press. I would not try and jimmy in bearings with a hammer. If in doubt contact The Saw Center and consider their package of bearing replacement and truing up the arbor flange. It’s actually inexpensive (less than a hundred) and they provide new bearings and true up the arbor flange in place making it just about as good as it gets.
Painting
Give some thought to painting. For the interior pieces Rustoleum Machinery Gray is just fine but will not be correct to the vintage of the saw. For a correct color find a painted part that has sat against another part (where the Trunnion Yoke sits against the Front and Rear Trunnion Assemblies is good). This surface will not have oxidized like exposed surfaces. A good paint store can computer analyze this surface and make up a perfect color match. You’ll need at least a pint of paint to spray a saw. (Note: Paint info may be available here.
If you decide to paint you’ll notice that time will appear to stand still. There’s nothing worse than waiting on paint to dry.
Reassembly
Lubrication
Dry Moly
Penetrating Lubricant
I am not recommending the brand and you can use an equal found locally to you.
Calibration
http://www.ts-aligner.com/newindex.htm
Now, do you need a $150 gizmo to re-align a top? No, though you do need to understand all that’s involved. Read what’s said at the above site and decide for yourself. I will say this. With a saw that’s properly tuned (a true arbor and flange aligned to the miter slots and with a fence aligned to the miter slots) you can get glue line rips with a good blade. Don’t feel like going through all of this? It’s your time and your money.
