Page Revision: 2008/04/04 12:31
Here's some pics of digging into a Baldor motor to repair a bad centrifugal switch.
Remove the fan cover
Remove the motor bolts
Here's the end bell
Here's the points that need filing, sanding, and otherwise smoothed out. Be careful not to bend the copper springs.
