Page Revision: 2008/04/10 03:33
Here's some pics of digging into a Baldor motor to repair a bad centrifugal switch posted by Bob Vaughan
here. in this example, the contacts were damaged and needed repair.
Remove the fan cover
Remove the motor bolts
Here's the end bell
