Page History: Crescent Heavy 8-inch Jointer
Page Revision: 2008/09/25 16:39
1903 Catalog
Crescent 8-inch Jointer
Length of tables | Front. 83; rear 30 inches. |
Height of table from floor. | 33 inches. |
Floor space required, over all | 21x64 inches. |
Cubic measure, boxed for export | 24 feet. |
Gross weight, boxed for export | 1,000 pounds. |
Net weight | 800 pounds. |
List price of machine | $130 |
Telegraphic code word | Ennoergie. |
