Page Revision: 2008/09/25 15:11
1903 Crescent Catalog
{The Frame of this machine has a large floor-base, is well braced and ribbed; and being cast all in one piece (including bearings) insures rigidity, and durability.
Floor space required, aver all | 31x80 | 37x80 | 43x80 |
Cubic Measure, boxed for export | 40ft. | 48ft. | 56ft. |
Gross Weight, boxed for export | 1,500 | 1,775 | 2,000 |
Net Weight | 1,250 | 1,450 | 1,650 |
List Price for Machine | $150 | $170 | $190 |
Telegraph Code Word | Ennovelar. | Ennoyage. | Ennuvear. |
