Page History: Decals - Delta Rockwell
Page Revision: 2020/12/26 19:55
The entry looks like this: [|][|][imageleft|Cat 1120 Motor Badge-Submitted by Larry Buskirk |{UP}/Decals/thumbnails/Cat 1120 Motor Badge T.jpg |{UP}/Decals/Cat 1120 Motor Badge.jpg]{clear}(Right click and select, in IE "SAve Target As", in Firefox "Save Link As")
GetFile.aspx?File=/Decals/thumbnails/Cat 1120 Motor Badge T.jpg is the thumbnail image. GetFile.aspx?File=/Decals/Cat 1120 Motor Badge.jpg is the decal image. We also recommend that the member who did the art work for each of the decals be identified for each entry below.
Delta Rockwell
Submitted by NeilB
Submitted by NeilB
Submitted by NeilB
Submitted by NeilB
Submitted by NeilB
Submitted by NeilB
Delta 15
Delta 15" Drill Press Logo
Delta 15
Delta 15" Drill Press Logo in Vector Format
Submitted by Kelly Verge (Right click and select "Save Target As" or "Save Link As" to download High-res version)
[imageleft|
||Rockwell Unisaw Badge by Giovanni, submitted by peds |GetFile.aspx?File=Decals/rockwell.tif|GetFile.aspx?File=Decals/rockwell.tif]
