Page Revision: 2009/04/24 22:28
IN PROGRESSTightening Screw Repair
By Bob Vaughan{Reference:http://www.owwm.org/viewtopic.php?t=41918|Delta 6x48 31-730 sander repair details(16 pictures)}
The bad shoulder
All Better
Additional Detail Pictures
These details show various problems one can encounter when buying a used sander{Reference:http://www.owwm.com/photoindex/detail.aspx?id=3717|belt sander body details}.
Table and inside groove:
Lower sanding cut:
