Page Revision: 2009/04/24 01:05
IN PROGRESSRepair
Machining or Grinding Flat
It is possible to repair a worn cast iron platen by machining or grinding it flat{Reference:http://owwm.org/viewtopic.php?t=27688|A Delta 6 X 48 Cast Iron Platen Reborn!}{Reference:http://owwm.org/viewtopic.php?t=41577|Worn drum on 6x48 sander}. The thickness of metal that will remain afterwards should be taken into consideration before choosing this option. Below are images from Bruce Erdman showing a platen with typical wear and the results after Blanchard grinding:
Flattening With Filler
On The Machine
By Shane Whitlock{Reference:http://owwm.org/viewtopic.php?t=49974|Rockwell Belt Sander Restoration Pics (updated all finished)}. You can see the platen is stamped steel instead of cast iron and it's in bad shape with more than a 1/8" bow in the center.
Graphited Canvas
Applying graphited canvas is reported to result in a cooler running belt, less load on the motor and provide inexpensive, easy to replace protection to a newly flattened platen.{Reference:http://owwm.org/viewtopic.php?t=41577|Worn drum on 6x48 sander}{Reference:http://owwm.org/viewtopic.php?t=36170|machining a 6x48 belt sander platen}
Setting the Table
See Also
