Page Revision: 2018/04/21 18:07
Repair
Machining or Grinding Flat
It is possible to repair a worn cast iron platen by machining or grinding it flat
A Delta 6 X 48 Cast Iron Platen Reborn!
Worn drum on 6x48 sander
The thickness of metal that will remain afterwards should be taken into consideration before choosing this option. Below are images from Bruce Erdman showing a platen with typical wear and the results after Blanchard grinding:
Flattening With Filler
On The Machine
By Shane Whitlock
Rockwell Belt Sander Restoration Pics (updated all finished). You can see the platen is stamped steel instead of cast iron and it's in bad shape with more than a 1/8" bow in the center.
Graphited Canvas
Applying graphited canvas is reported to result in a cooler running belt, less load on the motor and provide inexpensive, easy to replace protection to a newly flattened platen.
machining a 6x48 belt sander platen
Setting the Platen
Set a straightedge across the platen on both sides of the drums. The amount of drop should be the same. If not, shim out or in the platen. Also the platen can be set too low or high making the belt swell up in the middle as it runs. Most do this a little bit, but it shouldn't be too much.
Rockwell 6X48 belt tracking woes.......
See Also
