Page Revision: 2018/04/21 17:57
Tables
Comparison
The photo below from Bob Vaughan compares a table and trunnion from a late model disc/belt sander (left) with the older style (right). Note the repaired break on the late model trunnion, a known point of failure.Worn drum on 6x48 sander
Pics! Delta 6" Belt 12"DiskSander #31-730 for $100
Delta Belt/Disk Sander 31-730F
Table Lip Repair
Stops
