Page Revision: 2009/04/25 14:28
Tables
Comparison
The photo below from Bob Vaughan compares a table and trunnion from a late model disc/belt sander (left) with the older style (right). Note the repaired break on the late model trunnion, a known point of failure.{Reference:http://owwm.org/viewtopic.php?t=50230|Pics! Delta 6" Belt 12"DiskSander #31-730 for $100}{Reference:http://owwm.org/viewtopic.php?t=33372|Delta Belt/Disk Sander 31-730F}
Table Lip Repair
Stops
