Page Revision: 2008/04/10 21:48
(Note that pictures will be added to this wiki entry shortly.)
How to Properly Disassemble and Clean a Unisaw¶
If you are a first time restorer of woodworking machines you might want to read the
Restoration Guide.
The Tools You Will Need
- Hammer
- Set of Pin Punches
- Screwdrivers (note plural)
- Socket Set
- Combination Wrenches
- Straight Razor and Holder (Handle)
- Scotch Bright Pads (Coarse to Medium)
- WD-40
- Marvel Oil or Preferred Equivalent
- Parts Tubs (you can use cheap plastic shoe boxes or any container for this)
- Baggies (small sandwich size to large)
- Air Compressor
- Shop Vac
- Awl(s)
- Wire Brush
- Bench Brush (optional)
- Dead Blow or Rubber Mallet
Your next step is to take pictures. Take lots of pictures and while you are at it go to the Old WoodWorking Machines Web page and download a parts drawing. I like to take parts drawings and enlarge them at the copy machine at work (of course) and make several copies of each page. I use these in conjunction with a high lighter and make pages specifically for each of the major assemblies. That way I can clearly see what it is I’m working on and not be distracted by all the other parts. I also use parts drawings from different eras and actually sometimes prefer the newer drawings as they might show how parts are arraigned better than the older drawings.
Where to Start:
Now we’re getting serious and about to go beyond the point of no return. Believe it or not you can remove the entire guts of the saw with minor disassembly. I know because I did it. I did it for a couple of reasons. First it was because the shafts on my saw were so buggered up and grimy that I couldn’t remove them to facilitate an easier disassembly and second I did it onna ‘count of I was stupid. I’ll not lead you down that path but for the record the doing of this, removal with little disassembly, was as close to child birth as I will ever get and despite the fact that the official hat of the club of those of us that have done it is the dunce cap we are a proud bunch.
Now the real fun begins. Inspect the two shafts used for blade raising and blade tilting. These need to be removed but it’s very important that you follow the procedure. Don’t Ask Me How I Know This. If the shafts are the least bit grimy, clean them. Lube the shafts using WD-40 and start scrubbing with a course Scotch Bright pad. Get them clean. Shiny is not required. Next inspect the shafts for any buggering (raised metal) and file away the high spots with a fine metal file.
At this moment you should strongly consider replacing the arbor bearings. This can be done by you with the aid of an arbor press. I would not try and jimmy in bearings with a hammer. If in doubt contact The Saw Center (Google the name) and consider their package of bearing replacement and truing up the arbor flange. It’s actually inexpensive (less than a hundred) and they provide new bearings and true up the arbor flange in place making it just about as good as it gets.
Give some thought to painting. For the interior pieces Rustoleum Machinery Gray is just fine but will not be correct to the vintage of the saw. For a correct color find a painted part that has sat against another part (where the Trunnion Yoke sits against the Front and Rear Trunnion Assemblies is good). This surface will not have oxidized like exposed surfaces. A good paint store can computer analyze this surface and make up a perfect color match. You’ll need at least a pint of paint to spray a saw.
If you decide to paint you’ll notice that time will appear to stand still. There’s nothing worse than waiting on paint to dry. In reality you could dismantle and clean a Unisaw and have it al back together over a good weekend.
Dry Moly:
http://www.lpslabs.com/Products/Lubricants/Force842.aspPenetrating Lubricant:
http://www.lpslabs.com/Products/Lubricants/LPS1.aspI am not recommending the brand and you can use an equal found locally to you.
http://www.ts-aligner.com/newindex.htmNow, do you need a $150 gizmo to re-align a top? No, though you do need to understand all that’s involved. Read what’s said at the above site and decide for yourself. I will say this. With a saw that’s properly tuned (a true arbor and flange aligned to the miter slots and with a fence aligned to the miter slots) you can get glue line rips with a good blade. Don’t feel like going through all of this? It’s your time and your money.
Last but not least take pictures of you brand new saw. Send them to your friends, family and co-workers. Sure they won’t have a clue but what do you care, you’ve got a brand new saw!
