Page Revision: 2009/10/12 10:31
K-Line K2100 12-3/4” x 4” planer originally manufactured around 1948. Made by Kneisley Electric Company, rebadged by Foster Manufacturing and sold by Freeman Supply.
K2100
outfeed
Out feed side
tag
The entire casting of the K2100 is aluminum along with a 12-3/4” x 20” cast iron table. Even with that much aluminum and without the sheet metal stand and motor, the planer alone weighs 170 pounds.
guide plates
guide plates
Photos of the table guide plates used in the K2100 and changed in the next 12" K-Line model, the K2200. These are the guide plates that Tom Kneisley said were difficult to adjust and keep in adjustment. Each of the 2 - 6" x 6" plates are held in place by 4 bolts that need to be loosened in order to tighten or loosen the 6 adjusting set screws. The “in-out” process is a pain. The second picture shows the steel gib used to prevent or correct any wear on the guide plates. They are adjusted by 3 set screws and locked in place by 3 more set screws. The 1953 model K2200 was redesigned to use guide pins like the Yager/K2000 10” planers, needing no adjustment.
feed
feed
The feed and cutterhead assembly. The 3 knife cutterhead uses a couple 87505 bearings in the aluminum castings. Each knife is stamped “K-2504". Knurled in-feed and neoprene out-feed rollers use bronze flange bearings. The out-feed roller will need re-coating. Bottom photo shows tension feed roll springs with oil soaked felt wicks.
assy
Cutterhead pulley
assy
Feed roller gears
Aluminum casting with feed assembly attached with 8 bolts. Gears are cast iron.
clutch
clutch
bottom
motor
motor
Motor mount
toto
