Page Revision: 2009/10/12 16:16
K2100
K-Line K2100 12-3/4” x 4” planer originally manufactured around 1948. The entire casting of the K2100 is aluminum along with a 12-3/4” x 20” cast iron table. Even with that much aluminum and without the sheet metal stand and motor, the planer alone weighs 170 pounds.
outfeed
View from rear out feed side
tag
This K2100, serial number 6999, was made by Kneisley Electric Company, rebadged as Foster Manufacturing and sold by Freeman Supply.
guide plates
guide plates
Photos of the table guide plates used in the K2100 and changed in the next 12" K-Line model, the K2200. These are the guide plates that Tom Kneisley said were difficult to adjust and keep in adjustment. Each of the 2 - 6" x 6" plates are held in place by 4 bolts that need to be loosened in order to tighten or loosen the 6 adjusting set screws. The “in-out” process is a pain. The second picture shows the steel gib used to prevent or correct any wear on the guide plates. They are adjusted by 3 set screws and locked in place by 3 more set screws.
k2200
The 1953 model K2200 (right) was redesigned to use 2 table guide pins similar to the Yager/K2000 10” planers, needing no adjustment.
feed
The feed and cutterhead assembly. The 3 knife cutterhead uses a couple 87505 bearings in the aluminum castings. Each knife is stamped “K-2504". Knurled in-feed and neoprene out-feed rollers use bronze flange bearings. The out-feed roller will need re-coating.
feed
These are feed roller compression springs and screws with oil soaked felt wicks. Adjusting the screws increases or reduces the roller tension.
assy
View from cutterhead pulley. Aluminum casting with feed assembly attached with 8 bolts. Gears are cast iron.
assy
View from feed roller gears
clutch
clutch
bottom
motor
motor
Motor mount
toto
The K2100 alongside a Yager (later the K2000) 10-3/4" planer
pk cat
The K2000 and K2100 models from the 1949 Powr-Kraft catalog
