    Page Revision: 2009/01/15 22:11
Doug Westlind wrote:
- The paint was made originally at the S-W Granville, MI plant and is no longer stocked.
 - The Portland plant got the formula from Granville and can mix some up for me.
 - The cost will be in the neighborhood of $100/gal plus shipping (they are to get back to me on the final cost).
On August 9, 2006 Reg Mitchell reports the following custom Sherwin-Williams formula.  It is purportedly based on the formula from the Grand Rapids, MI Sherwin-Williams location that supplied Oliver directly...
From Shawn Wright
http://owwm.org/viewtopic.php?t=49652 :
