Page Revision: 2020/03/03 07:53
Doug Westlind wrote:
  1. The paint was made originally at the S-W Granville, MI plant and is no longer stocked.
  2. The Portland plant got the formula from Granville and can mix some up for me.
  3. The cost will be in the neighborhood of $100/gal plus shipping (they are to get back to me on the final cost).
On August 9, 2006 Reg Mitchell reports the following custom Sherwin-Williams formula. It is purportedly based on the formula from the Grand Rapids, MI Sherwin-Williams location that supplied Oliver directly...
OliverPaint
From Shawn Wright http://owwm.org/viewtopic.php?t=49652 :
Chuck Hess posted the following in the Oliver Photo Index:
I matched my color to an existing piece of factory paint on my planer and it was a long process. The paint store did not get it that this was something that I wanted to do over and over. Even after promising me they would keep the formula on file, they didnt. So the next machine we had to repeat this process. The color of my formula actually shifted a little during that chaos so it is not perfect dead on but very very close. We use a DuPont Centari Acrylic Enamel we get from an automotive supplier and it is awesome.
The formula is:
  • Mix size: 128 oz.
  • 758S Drier 200.8
  • 732A Fer Yellow 36.8
  • 742A Green/Vert 513.2
  • 00A White/Blanc 743.0
  • 741A Green/Vert 539.1
  • 705A Black/Noir 1617.4
  • 756A Clear/Clair 0.0
That is from the inside of the label.
On March 2, 2020 user Mud Face on owwm.org posted the following formula for a close match to early Oliver gray http://owwm.org/viewtopic.php?f=1&t=212096...
Sherwin-Williams
KL10-1890 Flathead Bronze
Custom Manual Match
BAC COLORANT   OZ  32  64  128
W1-White        -  11   -    -
B1-Black        -  38   1    1
R2-Maroon       -   -   1    -
Y3-Deep Gold    -   6   1    -
Quart      Ultradeep
A11T00214  640325775
