Page Revision: 2008/05/10 15:26
by Bill NanceIntroduction
Parks Model 95 Parts Index
A30 | Fluted Feed Roll | .75"OD | 1 | |
A31 | Hollow Head Set Screw | .75"OD | 1 | |
A32 | 12" Chip Breaker | .75"OD | 1 | |
A33 | 12" HSS Knives | .75"OD | 1 | |
A34 | Complete Roller Chain | .75"OD | 1 | |
A35 | Connecting Link for Chain | .75"OD | 1 | |
A36 | Pressure Bar | .75"OD | 1 | |
A37 | Hood Stud | .75"OD | 1 | forgot to take pics of these |
A38 | Shaving Hood | .75"OD | 1 | View of Top |
A38 | Shaving Hood | .75"OD | 1 | View of Bottom |
A39 | Lock Nut for Hood | .75"OD | 1 | |
A40 | Adjusting Stud for Hood | .75"OD | 1 | |
