Page Revision: 2008/05/11 00:19
Parks Model 95 Parts Index
A43 | Table | - | 1 | |
A51 | Compression Spring | - | 1 | |
A52 | Roll Bearing Stud | 1.25" | 1 | |
A53 | Pressure Bar Stud | 1.25" | 1 | |
A54 | Smooth Feed Roll Bearing | 1.25" | 1 | |
A55 | Stud Collar | 1.25" | 1 | |
A56 | Fluted Feed Roll Bearing | 1.25" | 1 | |
A57 | Bearing Cap Stud | 1.25" | 1 | |
A58 | Bearing Cap | 1.25" | 1 | |
A59 | Left Side Casting | 1.25" | 1 | |
A60 | | 1.25" | 1 | |
