Page Revision: 2008/05/11 00:40
Parks Model 95 Parts Index
A43 | Table | - | 1 | |
A60 | Right Side Casting | 1.25" | 1 | |
A61 | Base | 1.25" | 1 | |
A62 | Elevating Shaft | 1.25" | 1 | |
A63 | Shaft Collar | 1.25" | 1 | forgot to take photos |
A64 | Bevel Gear L102 | 1.25" | 1 | |
A65 | Elevating Screw | 1.25" | 1 | |
A66 | Column Tie Rod | 1.25" | 1 | |
A67 | Hand Wheel and Handle | 1.25" | 1 | Top View |
A67 | Hand Wheel and Handle | 1.25" | 1 | Bottom View |
A68 | Depth Indicator | 1.25" | 1 | |
A69 | Depth Scale | 1.25" | 1 | |
A70 | | 1.25" | 1 | |
