Page Revision: 2008/05/19 01:53
UNDER CONSTRUCTION
Parks Model 95 Parts Index
A27 | Head Shaft Spacer | | 1 | |
A37 | Hood Stud | - | 2 | |
A43 | Table | - | 1 | |
A63 | Shaft Collar | 5/8"ID | 4 | |
A73 | [GetFile.aspx?File=Parks12InchPlanerParts%2fP95_A73_jamnut5_8thick.jpg| Jam Nut 5/16" thick | 5/16" thick | 2 | for pressure bar mount |
A74 | [GetFile.aspx?File=Parks12InchPlanerParts%2fP95_A74_jamnut3_8thick.jpg|Jam Nut 3/16" thick | 3/16" thick | 6 | for roll bearing and pressure bar studs |
na | Drain Plug | - | 1 | |
