Page Revision: 2008/05/10 13:24
by Bill NanceIntroduction
Parks Model 95 Parts Index
A2 | Shaft Collar | .75" ID, 1.25" OD | 3 |
A3 | Hollow Head Set Screw | 3/16" | ? | |
A4 | 12 Tooth Sprocket | .75" ID, 1.37" OD | 2 | 2.25" exterior sprocket diameter |
A6 | | .75" ID, 1.25" OD | 3 | |
A7 | | .75" ID, 1.25" OD | 3 | |
A8 | | .75" ID, 1.25" OD | 3 | |
A9 | | .75" ID, 1.25" OD | 3 | |
A10 | | .75" ID, 1.25" OD | 3 | |
