Page Revision: 2008/05/19 02:04
by Bill NanceIntroduction
1949 Operating Instructions and Parts List for Parks 12" Thickness Planer found in the OWWM Publication Reprints. Missing parts or photos were kindly provided by Doug Rewerts, resident OWWM Parks guru. Wiki contributors are encouraged to edit/replace with individual parts as available/appropriate, but are also requested asked to please indicate in the table's comments section any information that references a different operating manual.
Parks Model 95 Parts Index
A27 | Head Shaft Spacer | | 1 | |
A37 | Hood Stud | - | 2 | |
A43 | Table | - | 1 | |
A63 | Shaft Collar | 5/8"ID | 4 | |
A73 | Jam Nut 5/16" thick | 5/16" thick | 2 | for pressure bar mount |
A74 | Jam Nut 3/16" thick | 3/16" thick | 6 | for roll bearing and pressure bar studs |
na | Drain Plug | - | 1 | |
