Page Revision: 2009/02/13 13:36
FormatYearsComments
1948—53Early machines did not have serial numbers.
mnnn 1953—55"m" is a digit that varied according to machine type. "nnn" is the number of the machine within this series.
N-nnnn 1955—64"N" is the unit digit of the year, beginning in 1955. "nnnn" is the number of the machine for that year.
6N-nnnn 1965—68"N" is the unit digit of the year, beginning in 1965. "nnnn" is the number of the machine for that year.
NMM-nnnn 1968—77"N" is the unit digit of the year, beginning in 1968.
NNMM-nnnn 1968—??"NN" is the last two digits of the year, beginning in 1978.
Examples
A Powermatic Model 60 8-inch jointer has serial number 3451. According to the table under "Jointers", below, the model 60 used the pattern "3nnn" during the period 1953 to 1955.
Another Model 60 jointer has serial number 8-3932, which matches the pattern "N-nnnn", placing it between 1958 and 1967; "N" is 8 so this jointer was made in 1958.
A Model 400 hollow-chisel mortiser has serial number 540045. The serial-number table for Mortisers, below, does not have any data for a Model 400. But looking at the general table, above, we tentatively decide that it is of the form "NMM-nnnn" where MM is either 40 or 400, N is 5, and "nnn" is 045, implying that the machine is the 45th such machine made in 1975. For this mortiser we would be well advised to use other clues such as the original paint color to verify this date. We can do this by comparing the machine to other machines from 1975 in the Photo Index.
Band Saws, Wood-Cutting
FormatYearsComments
Model 80
N-nnnn1955—??"N" is the units digit of the year, beginning in 1955. "nnnn" is the number of the machine for that year.
Model 81
N-nnnn1960—68"N" is the units digit of the year, beginning in 1960. "nnnn" is the number of the machine for that year.
N81-nnnn1968—77"N" is the units digit of the year, beginning in 1968. "nnnn" is the number of the machine for that year.
NN81-nnnn1978—??"NN" is the last two digits of the year, beginning in 1978. "nnnn" is the number of the machine for that year.
Model 140
Model 141
N-nnnn1961—68"N" is the units digit of the year, beginning in 1955. "nnnn" is the number of the machine for that year.
N41-nnnn1968—77"N" is the units digit of the year, beginning in 1968. "nnnn" is the number of the machine for that year.
NN41-nnnn1978—??"NN" is the last two digits of the year, beginning in 1978. "nnnn" is the number of the machine for that year.
Band Saws, Metal-cutting
FormatYearsComments
Model 2
N-nnnn1965—68"N" is the units digit of the year, beginning in 1965. "nnnn" is the number of the machine for that year.
N02-nnnn1968—??"N" is the units digit of the year, beginning in 1968. "nnnn" is the number of the machine for that year.
Model 5
N-nnnn1964—68"N" is the units digit of the year, beginning in 1964. "nnnn" is the number of the machine for that year.
N05-nnnn1968—??"N" is the units digit of the year, beginning in 1968. "nnnn" is the number of the machine for that year.
Model 6
N06-nnnn1970—??"N" is the units digit of the year, beginning in 1970. "nnnn" is the number of the machine for that year.
Model 8
N08-nnnn1968—??"N" is the units digit of the year, beginning in 1970. "nnnn" is the number of the machine for that year.
Model 83 (Friction cutting)
No serial numbers.
Model 85
No serial numbers.
Model 86
N-nnn1959—??"N" is the units digit of the year, beginning in 1959. "nnn" is the number of the machine for that year.
Model 87
N87-nnnn1968—77"N" is the units digit of the year, beginning in 1968. "nnnn" is the number of the machine for that year.
NN87-nnnn1978—??"NN" is the last two digits of the year, beginning in 1978. "nnnn" is the number of the machine for that year.
Model 88
N88-nnnn1974—78"N" is the units digit of the year, beginning in 1974. "nnnn" is the number of the machine for that year.
NN88-nnnn1978—??"NN" is the last two digits of the year, beginning in 1978. "nnnn" is the number of the machine for that year.
Model 89
N89-nnnn1969—??"N" is the units digit of the year, beginning in 1969. "nnnn" is the number of the machine for that year.
Drill Presses
FormatYearsComments
Model 1100
N-nnnn1955—??"nnnn" is the number of the machine.
Model 1150
N-0nnn1964—68"nnnn" is the number of the machine.
N15X-nnnn1968—76"N" is the units digit of the year, beginning in 1968. "X" is the letter V or S. "nnnn" is the number of the machine for that year.
Model 1150A
N15X-nnnn1976—78"N" is the units digit of the year, beginning in 1976. "X" is the letter V or S. "nnnn" is the number of the machine for that year.
NN15X-nnnn1978—78"NN" is the last two digits of the year, beginning in 1978. "X" is the letter V or S. "nnnn" is the number of the machine for that year.
Model 1200
N-1nnn1955—64"nnnn" is the number of the machine.
NN-nnnn1965—68"NN" is the last two digits of the year, beginning in 1965. "nnnn" is the number of the machine for that year.
N20X-nnnn1976—78"N" is the units digit of the year, beginning in 1976. "X" is the letter V or S. "nnnn" is the number of the machine for that year.
NN20X-nnnn1978—78"NN" is the last two digits of the year, beginning in 1978. "X" is the letter V or S. "nnnn" is the number of the machine for that year.
Jointers
FormatYearsComments
Model 50 (6 inch)
11nnn1955—60"nnn" is the number of the machine.
N-nnnn1960—65"N" is the units digit of the year, beginning in 1960. "nnn" is the number of the machine for that year.
6N-nnnn1965—68"N" is the units digit of the year, beginning in 1965. "nnnn" is the number of the machine for that year.
N50-nnnn1968—77"N" is the units digit of the year, beginning in 1968. "nnnn" is the number of the machine for that year.
NN50-nnnn1978—??"NN" is the last two digits of the year, beginning in 1978. "nnnn" is the number of the machine for that year.
Model 60 (8 inch)
3nnn1957"nnnn" is the number of the machine within this version.
N-nnnn1958—67"N" is the units digit of the year, beginning in 1958. "nnnn" is the number of the machine within this version.
N61-nnnn1968—77"N" is the units digit of the year, beginning in 1968. "nnnn" is the number of the machine for that year.
NN61-nnnn1978—??"NN" is the first two digits of the year, beginning in 1978. "nnnn" is the number of the machine for that year.
Lathes, Wood
FormatYearsComments
Model 45
N-1nnn1960—68"N" is the units digit of the year, beginning in 1960. "nnn" is the number of the machine for that year.
N45-nnnn1968—77"N" is the units digit of the year, beginning in 1968. "nnnn" is the number of the machine for that year.
NN45-nnnn1978—??"NN" is the last two digits of the year, beginning in 1978. "nnnn" is the number of the machine for that year.
Model 90
0-nnnn1955—68"nnnn" is the number of the machine within this version.
N90-nnnn1968—77"N" is the units digit of the year, beginning in 1968. "nnnn" is the number of the machine for that year.
NN90-nnnn1978—??"NN" is the first two digits of the year, beginning in 1978. "nnnn" is the number of the machine for that year.
Mortisers
FormatYearsComments
Model 2A Chain
Model 15 Chain
2nnn1953—55"nnn" is the number of the machine within this version.
N-nnnn1955—64"N" is the units digit of the year, beginning in 1955. "nnnn" is the number of the machine for that year.
Model 30 Hydraulic Chain
Model 40 Hydraulic Chain
Model 41 Hydraulic Chain
Model 10 Hollow Chisel
2nnn1948—55"nnn" is the number of the machine within this version. Beginning year (1948) is estimated.
N40-nnnn1968—77"N" is the units digit of the year, beginning in 1968. "nnnn" is the number of the machine for that year.
NN40-nnnn1978—??"NN" is the last two digits of the year, beginning in 1978. "nnnn" is the number of the machine for that year.
Planers
FormatYearsComments
Model 2A (20 inch)
1930—??This model did not have serial numbers.
Model 3A (24 inch)
Model 12 (12 inch)
nnnn1950—??"nnnn" is the number of the machine.
Model E 16 (16 inch)
nnnn19??—??"nnnn" is the number of the machine, beginning with 7001.
Model 100 (12 inch)
nnnn1955—55"nnnn" is the number of the machine, beginning with 6200.
N00-nnnn1968—77"N" is the units digit of the year, beginning in 1968. "nnnn" is the number of the machine for that year.
NN00-nnnn1978—??"NN" is the last two digits of the year, beginning in 1978. "nnnn" is the number of the machine for that year.
Model 160 (16 inch)
N-nnnn1959—67"N" is the units digit of the year, beginning in 1959. "nnnn" is the number of the machine for that year.
N60-nnnn1968—77"N" is the units digit of the year, beginning in 1968. "nnnn" is the number of the machine for that year.
NN60-nnnn1978—??"NN" is the last two digits of the year, beginning in 1978. "nnnn" is the number of the machine for that year.
Model 180 (18 inch)
N-nnn1961—68"N" is the units digit of the year, beginning in 1961. "nnn" is the number of the machine for that year.
N80-nnnn1968—77"N" is the units digit of the year, beginning in 1968. "nnnn" is the number of the machine for that year.
NN80-nnnn1978—??"NN" is the last two digits of the year, beginning in 1978. "nnnn" is the number of the machine for that year.
Model 220 (20 inch)
nnnn1952—55"nnnn" is the number of the machine, beginning with number 5100.
Model 221 (20 inch)
N-nnnn1955—64"N" is the units digit of the year, beginning in 1955. "nnnn" is the number of the machine, beginning with 5525.
6N-nnnn1965—67"N" is the units digit of the year, beginning in 1965. "nnnn" is the number of the machine.
N22-nnnn1968—77"N" is the units digit of the year, beginning in 1968. "nnnn" is the number of the machine.
NN22-nnnn1978—??"NN" is the last two digits of the year, beginning in 1978. "nnnn" is the number of the machine.
Model 224 (24 inch)
nnnn1955—57"nnnn" is the number of the machine, beginning with number 8001.
Model 225 (24 inch)
nnnn1957—60"nnnn" is the number of the machine, beginning with number 8360.
N-nnnn1960—67"N" is the units digit of the year, beginning in 1965. "nnnn" is the number of the machine.
N25-nnnn1968—77"N" is the units digit of the year, beginning in 1968. "nnnn" is the number of the machine.
NN25-nnnn1978—??"NN" is the last two digits of the year, beginning in 1978. "nnnn" is the number of the machine.
Sanders
FormatYearsComments
Model 30
N30-nnnn1968—77"N" is the units digit of the year, beginning in 1968. "nnnn" is the number of the machine for that year.
Model 30A
N30Annnn1969—77"N" is the units digit of the year, beginning in 1969. "nnn" is the number of the machine for that year.
NN30-nnnn1978—??"NN" is the last two digits of the year, beginning in 1978. "nnnn" is the number of the machine for that year.
Model 30B
Model 33
N33-nnnn1968—77"N" is the units digit of the year, beginning in 1968. "nnnn" is the number of the machine for that year.
Model 33B
NN33-nnnn1978—??"NN" is the last two digits of the year, beginning in 1978. "nnnn" is the number of the machine for that year.
Model 35
N35-nnnn1968—77"N" is the units digit of the year, beginning in 1968. "nnnn" is the number of the machine for that year.
Model 35B
NN35-nnnn1978—??"NN" is the last two digits of the year, beginning in 1978. "nnnn" is the number of the machine for that year.
Scroll Saws
FormatYearsComments
Model 95
N-nnn1961—68"N" is the units digit of the year, beginning in 1961. "nnnn" is the number of the machine for that year.
N95-nnnn1968—77"N" is the units digit of the year, beginning in 1968. "nnnn" is the number of the machine for that year.
NN95-nnnn1978—??"NN" is the last two digits of the year, beginning in 1978. "nnnn" is the number of the machine for that year.
Spindle Shaper
FormatYearsComments
Model 25
N-nnnn1961—65"N" is the units digit of the year, beginning in 1955. "nnnn" is the number of the machine for that year.
Model 26
N26-nnnn1968—77"N" is the units digit of the year, beginning in 1968. "nnnn" is the number of the machine for that year.
NN26-nnnn1978—??"NN" is the last two digits of the year, beginning in 1978. "nnnn" is the number of the machine for that year.
Tilting Arbor Saw (Tablesaw)
FormatYearsComments
Model 62
N-nnn1964—68"N" is the units digit of the year, beginning in 1964. "nnn" is the number of the machine for that year.
N62-nnnn1968—77"N" is the units digit of the year, beginning in 1968. "nnnn" is the number of the machine for that year.
NN62-nnnn1978—??"NN" is the last two digits of the year, beginning in 1978. "nnnn" is the number of the machine for that year.
Model 65
N-nnn1955—65"N" is the units digit of the year, beginning in 1955. "nnn" is the number of the machine for that year.
NN-nnn1965—??"NN" is the last two digits of the year, beginning in 1965. "nnn" is the number of the machine for that year.
Model 66
66-nnn1965—68"nnn" is the number of the machine for the series.
N66-nnnn1968—77"N" is the units digit of the year, beginning in 1968. "nnnn" is the number of the machine for that year.
NN66-nnnn1978—??"NN" is the last two digits of the year, beginning in 1978. "nnnn" is the number of the machine for that year.
Model 68
N68-nnnn1972—78"N" is the units digit of the year, beginning in 1972. "nnnn" is the number of the machine for that year.
NN68-nnnn1978—??"NN" is the last two digits of the year, beginning in 1978. "nnnn" is the number of the machine for that year.
Model 70
1nnn1954—55"nnn" is the number of the machine for the series.
N-nnnn1955—60"nnnn" is the number of the machine.
Model 71
N-nnn1960—??"N" is the units digit of the year, beginning in 1960. "nnn" is the number of the machine, beginning with "600" in 1960.
Model 72
N-nnn1958—67"N" is the units digit of the year, beginning in 1958. "nnn" is the number of the machine.
N72-nnn1968—77"N" is the units digit of the year, beginning in 1968. "nnn" is the number of the machine.
NN72-nnn1978—??"NN" is the last two digits of the year, beginning in 1978. "nnn" is the number of the machine.
Tenoners, Single-End
FormatYearsComments
Model 2
Model 2A
N28-nnnn1968—77"N" is the units digit of the year, beginning in 1968. "nnnn" is the number of the machine for that year.
NN32-nnnn1978—??"NN" is the last two digits of the year, beginning in 1978. "nnnn" is the number of the machine for that year.
