Page Revision: 2009/06/16 20:11
I had a step pulley from a small belt driven drill press that had a chunk taken out of the uppermost pulley. This is the fix I used. This idea was offered by Carla. I appreciate her help and wish to acknowledge her contribution.
Broken pulley
Broken pulley
Remove broken edge
Remove broken edge
Machine a large flat washer or other material to replace the broken piece. The ID of the washer was cut .005 inches SMALLER than the diameter of the groove cut into the pulley for an interference fit. Once the washer was heated and installed I machined the OD to the original size.
Flat washer machined
I heated the washer and installed it on the machined pulley.
Washer installed and pulley painted
