Page Revision: 2009/06/16 20:14
I had a step pulley from a small belt driven drill press that had a chunk taken out of the uppermost pulley. This is the fix I used. This idea was offered by Carla. I appreciate her help and wish to acknowledge her contribution.
Broken pulley
Broken pulley
Remove broken edge
Remove broken edge
Flat washer machined
I heated the washer, installed it on the machined pulley, and then machined the OD to the original size.
Washer installed, machined, and painted
