I had a step pulley from a small belt driven drill press that had a chunk taken out of the uppermost pulley. This is the fix I used. This idea was offered by Carla. I appreciate her help and wish to acknowledge her contribution. And thanks to Jeff J. for reformatting the text. (SWMBO was rushing me to go see our new grandson when I wrote the article).
![Broken pulley](http://i148.photobucket.com/albums/s24/DOXIN/burkedppulley.jpg) Broken pulley |
![Remove broken edge](http://i148.photobucket.com/albums/s24/DOXIN/cutbrokenrim.jpg) Remove broken edge |
![Cut a groove to accept the repair](http://i148.photobucket.com/albums/s24/DOXIN/cutridge.jpg) Cut a groove to accept the repair |
![Flat washer machined](http://i148.photobucket.com/albums/s24/DOXIN/machinedwasher.jpg) Flat washer machined |
I heated the washer, installed it on the machined pulley, and then machined the OD to the original size.
![Washer installed, machined, and painted](http://i148.photobucket.com/albums/s24/DOXIN/repairedpulley2.jpg) Washer installed, machined, and painted |
