Page History: Patching sheet metal holes using low temp solder.
Page Revision: 2008/04/18 23:32
before and after
before and after
Getting Started
holes to be patched
Prep
stripped and cleaned
A filler for the holes is needed, I used some soft copper from a pipe hanging fixture, hammered flat it was a perfect thickness for this application. For thicker sheet metal, an old copper penny might be a quick and cheap source of material. Using lineman's pliers, the plug is cut to shape, slowly snipping into a circle. When I got to where it fit, I pressed it into the hole using the same pliers.
plug pressed in place
Soldering
soldered
backside
Filing and Sanding
dressing down
The finished product
finished left and right
finished front
finished back
Remember:
Do all metal hammering and straightening first.
Clean area well.
