by Keith S. Rucker
Part 3 - Finishing up
1 - Sunday, December 5, 2004
1.1 - Mount Bearings
1.2 - Installing New Tires
I ordered my tires from Carter Products Company, Inc. I decided to go with the black Stretch On Rubber Tires rather than the "Ultra Blue" Urethane Tires simply because the blue tires would not look original on my restored saw. I also ordered two part epoxy to cement the tires to the rims of the saw. The tires came complete with instructions, written by none other than OWWM's own Bob Vaughan! Figuring that Bob knows well what to do, I followed the instructions to the tee.
 Notice slight crown in center of wheel. You can see light under both sides of the straight edge. The crown is actually greater than what this picture looks like.
2 - Tuesday, December 7, 2004
Pearl Harbor Day. Kind of cool to think that when the Japs attacked us on this day in 1941, this Crescent band saw had already been in operation for around thirty years! No telling what this machine helped churn out for the war effort. Oh well, I digress.
Today, I spent some time installing the tight/loose pulleys. Unfortunately, the original pulleys had long been separated from this band saw when it was at some point in time converted to a vee-belt, motor driven machine. Since this machine will once again be run from flat belts and and overhead line shaft, I had to find a matched set of tight/loose pulleys. Tight/loose pulleys work by one pulley being tightened to the drive shaft and another pulley, installed right next to it having a bronze or babbitt bearing in it and turning freely on the shaft. The flat belt running up to the main line shaft would always be turning as long as power was on the line. To engage the machine, you would shift the belt from the loose pulley over to the tight pulley, which would power up the machine.
3 - Saturday, December 11, 2004
4 - Monday, December 13, 2004
The remainder of the shift linkage was made today. Because I was using pulleys that were slightly larger than original, I had to adapt things a bit to move the shifting forks a little further away from the pulleys. For the portion where the two pieces of rod meet perpendicular to one another at the base, I used a piece of 3/4" black pipe to slide on the 3/4" rod on the frame. On this, I welded a piece of 1 1/4" square steel with two 3/4" holes drilled in at 90 degree angles to one another - one to hold the shift handle linkage and the other to go to the shift forks. I salvaged two shift forks from my scrap pile - they are straight rather than curved but will do the same function.
5 - Saturday, December 18, 2004
The only minor thing that remains to be done is replace some parts on the Wright guides. When I got the saw, it did not have the original Wright guides but a fellow OWWM'er had a set he was not using and sent them my way. They needed new pads on the jaws and the bottom guide needed a new bearing and wheel. The parts have been ordered but have not come in yet. As soon as they get here, it will take all of about five minutes to install them.
Here are some "finished" pictures of the saw.
The finished saw installed at the Georgia Agrirama
