Removing Upper Shaft
Removing spindle from Delta 6x48 sander.. continued
Rockwell 6x48 Belt Sander Bearings
Delta sander 31-710 bearing removal
Rockwell 6x48 sander
Starting rebuild of 31-710 belt/disk, any hints?
  • Add additional support for the casting so it does not bend down. The challenge with this technique is that the casting may end up taking all the load, in which case it will certainly break.
  • A technique that has been used on a similar bearing setup on a different machine is to first remove the balls from the lower bearing: pop off the seal, drill and pry out the bearing cage, move all the balls to one side, then pop them out. Now the shaft will be free to come out without applying any pressure to the bottom of the casting. Ensure that the inner race is not catching on the outer race before applying full pressure.
Belt sander upper shaft details
Comparisons to Powermatic 30
By Bob Vaughan
6x48 sander drum shaft sizes
Shaft Fabrication
By Bob Vaughan
Shaft fabrication is easy with a metal lathe. Take 15mm ground rod (see links below for source) and thread the ends to fit the fine nuts you have. Newer shafts have different threads to older ones (see pictures above).
Delta 6x48 upper (idler) shaft question?
Bearing Information
When fitting extended race bearings to this sander, the extended portion of the race should be exposed to the elements, that is the races of the two bearings should extend away from each other.
Opps, 31-710 sander, ext. races, in or out? Dr. Vaughan?
