I had a step pulley from a small belt driven drill press that had a chunk taken out of the uppermost pulley. This is the fix I used. This idea was offered by Carla. I appreciate her help and wish to acknowledge her contribution. And thanks to Jeff J. for reformatting the text. (SWMBO was rushing me to go see our new grandson when I wrote the article).
Broken pulley
Broken pulley
Remove broken edge
Remove broken edge
Flat washer machined
I heated the washer, installed it on the machined pulley, and then machined the OD to the original size.
Washer installed, machined, and painted
