by Keith Bohn
The purpose of this guide is to allow most any amateur interested in vintage machinery to gain some of the basic information required to start and complete a restoration. With so many different makes, models and machine types it would be nearly impossible to cover everything here. If you are looking for specific information please feel free to take part in the OWWM discussion group. In the mean time, this guide can act as your jumping off point and hopefully get you started.
1 - Getting Started
This Unisaw is nearly identical to every Unisaw ever built. A parts drawing for a newer saw was used along with one vintage to the saw during its restoration.
2 - Pre-Tearing Down
No one would ever believe this saw could have ever been green but people will wonder why after it's done.
3 - The Tear Down
  • Baggies
  • Sharpie Permanent Marker
  • Plastic Bins
  • Cardboard Boxes
  • Paper Tags with Strings
Parts here have been bagged, cataloged and placed into plastic tubs to help keep track of them.
  • Everything In Your Tool Box
  • Brushes
  • Pin Punches
  • Gear Puller
  • Every Tool You’ve Wanted But Could Not Justify Till Now
4 - Put Together A Game Plan
About five minutes after buying a vintage machine the typical buyer begins to form a game plan of how to go about restoration. There are a few ways to tackle this job.
  1. Tear the whole thing down bit by bit, piece by piece, clean everything up at once, re-paint and reassemble. This is not for the faint of heart especially when you find yourself looking at a few hundred parts.
  2. Tear down the machine into manageable components and work from the ground up. This means starting with the stand, working up to the part or assembly that fastens itself to the stand until you've gotten all the way to the table. This method can be tedious but there is a trade off with your sanity. I also favor this for storage reasons. A machine broken down into bite size chunks can be rat holed better.
  3. This involves a mix of both. Consider that you'll probably only want to visit the sand blaster once. It makes sense to get those pieces ready for blasting and get that over with. Cleaning metal parts, priming all the parts and finally painting all the parts at once will save you some time and effort. Personally, I'm in it for the fun so time means little to me.
This saw was taken apart to easily get it into a basement shop. The baggies contain parts for the base.
5 - Tags & Decals
6 - The Cleaning
A couple of parts soaking in Super Clean prior to scrubbing.
This Scotch Bright wheel quickly cuts through rust, tarnish and grime. The smaller wheel give a little more polished finish.
A before Scotch Bright and after Scotch Bright picture. Can you tell which is which?
7 - Table Surfaces
8 - Repair
9 - Taping and Masking
10 - Primer and Paint
11 - Reassembly
This is the same saw shown at the top of this article. The restoration took just over a month of weekends and some week nights. It was time well spent
