The following article is reproduced from a posting to the owwm.org "Shop" forum by Barry Willis.I recently bought an old Delta "DP220" 15" drill press which had a broken switch. Some of these old Delta switches can be hard to come by. (Boy, I sure hope so, after the work I put in on this.) So I fixed it. I always enjoy sharing too, so I documented what I did. I hope you enjoy this.
This was the switch:
My solution is to simply grind the flat top of the bolts down to the level of the switch top and remove the bolts. We’ll fix the shortened bolts later. Note the lettering on the metal switch top
PAT NO 1889259. Also note the similar lettering on the Bakelite bottom. On this switch this lettering reads the same direction. That is, when this switch is rotated on its axis, the lettering top and bottom is left to right. Look for, and note, your switch’s indications of direction so you can reassemble it correctly. This matters.
The patent drawing (courtesy Jeff Joslin) might help you visualize the switch internals. It is shown below left.
Patent drawing
Remove the switch top:
A word about toggle pins. . .
PIN TYPE ONE:
PIN TYPE TWO:
MAKE A NEW TOGGLE:
The idea for this process came to me suddenly when I was a teenager back in the 70’s. I asked, “Dad, can I borrow the car keys?” (light bulb=”on”).
REASSEMBLY:
Finish it up with a little solder on the bolts and grind them only enough to make the clearance needed for the switch plate. Leave enough soldered bolt exposed to keep the bolts in place. Notice the height of the left bolt created by the additional countersink of the holes. This was ground to the level of the original pressed bolts. Well, this is my finished switch:
A repair to a similar switch was discussed in another forum thread:
Delta #1115 Switch Repair.
