Serial No.TypeMachine DescriptionDate
250Chucking Machines#76H Chucking MachineDec 1935
475Chucking Machines#76H Chucking MachineDec 1947
45-4109-1Transfer Presses#3 Multiple Transfer PressDec 1935
46-4109-19Transfer Presses#3 Multiple Transfer PressDec 1947
44-4063-1Transfer Presses#4 Multiple Transfer PressDec 1947
40-3566-1Transfer Presses#5 Multiple Transfer PressDec 1935
42-3566-3Transfer Presses#5 Multiple Transfer PressDec 1947
37-442-11Open Back Bench Presses#1 Open Back Bench PressDec 1935
45-442-78Open Back Bench Presses#1 Open Back Bench PressDec 1947
38-883-1Open Back Bench Presses#2 Open Back Bench PressDec 1935
46-883-78Open Back Bench Presses#2 Open Back Bench PressDec 1947
41-3636-1Four Slide Wire Forming Machine#00 Four Slide Wire Forming MachineDec 1935
46-3636-53Four Slide Wire Forming Machine#00 Four Slide Wire Forming MachineDec 1947
39-1628-1Four Slide Wire Forming Machine#1 Four Slide Wire Forming MachineDec 1935
46-1628-64Four Slide Wire Forming Machine#1 Four Slide Wire Forming MachineDec 1947
38-1606-1Four Slide Wire Forming Machine#2 Four Slide Wire Forming MachineDec 1935
46-1606-72Four Slide Wire Forming Machine#2 Four Slide Wire Forming MachineDec 1947
38-3200-1Four Slide Wire Forming Machine#3-24 Four Slide Wire Forming MachineDec 1935
46-3200-26Four Slide Wire Forming Machine#3-24 Four Slide Wire Forming MachineDec 1947
38-1440-1Four Slide Wire Forming Machine#4-5 Four Slide Wire Forming MachineDec 1935
47-1440-31Four Slide Wire Forming Machine#4-5 Four Slide Wire Forming MachineDec 1947
40-271-1Four Slide Wire Forming Machine#8 Four Slide Wire Forming MachineDec 1935
47-271-1Four Slide Wire Forming Machine#8 Four Slide Wire Forming MachineDec 1947
43-3820-1Vertical Continuous Lathe#54VC Vertical Continuous LatheDec 1935
45-3820-13Vertical Continuous Lathe#54VC Vertical Continuous LatheDec 1947
Note: #4 Four Slide Wire Forming Machine was renumbered as #5.
