1934 - 1936 14" Bandsaw
  • Models: 890- Bare Bandsaw, 892- Woodcutting Unit, 896- Metalcutting Unit
  • Wheel Cover Decal: Delta Specialty decal
  • Wheel Cover Knobs: LBS 177 Knurled steel
  • Wheel Cover Type: Stamped steel with rounded edges on the face, three raised rays, and raised center hub.
  • Serial Number Badge: None
  • Patent Decal: 1934 saws lack the patent decal.
  • Color:
  • Wheel Type: Solid steel dish-type
  • Table: ?x?, no miter slot
  • Stand Types: 891- Steel Stand
  • Switch Plate: None
  • Switch: Switch installed in motor, 851- Switch Rod available.
  • Motor Options: 800- 1/3 hp split-phase, 900- 1/3 hp R-I, 820- 1/2 hp R-I
  • Belt:
  • Belt Guard: None available.
  • Blade: 93" standard, 105" with riser block
  • Accessories: 882- lamp, 894- 6" riser block, 893- fence w/ 18" rails, 895- fence w/ 32" rails
Lower guide separate from lower trunnion assembly.
1937 Improved 14" Bandsaw
  • Models: 890- Woodcutting, 880- Metalcutting
  • Wheel Cover Badge: Red circle, three vertical stripes, DELTA angled up from left to right.
  • Patent Decal: Yes
  • Knobs: Knurled steel
  • Wheel Cover Type: Stamped steel with rounded edges on the face. Lacks the raised rays and hub from the previous version.
  • Color:
  • Wheel Type:
  • Stand Types:
  • Switch Plate:
  • Switch:
  • Motor Options:
  • Belt:
  • Belt Guard: Cast iron belt guard available
