Early Band Saws in the VintageMachinery Archives: A Research Paper in Eight Parts
Part 1. Patent dates and four footed cast iron, cast iron wheeled band saws
The VintageMachinery.org archive as of this writing (November 20, 2006) lists nine (9) four footed cast iron, cast iron wheeled band saws.
Welch & Chipman saw
Welch, Harrison & Co. saw
C.B. Rogers & Co saw
Both the Welch, Harrison and the Welch & Chipman saws have the patent date of June 16, 1868 cast into them, and, therefore both saws were manufactured after that date. The four Pryibil related saws have several patent dates attached or cast onto them, as follows:
First & Pryibil (Steere example)August 28, 1866 & Jan 7, 1873
First & Pryibil ('Woodshave' example)said to be 1876
Pryibil (Poore example)August 28, 1866 & Jan 7, 1873
Pryibil (Barnhart example)August 28, 1866 & Jan 7, 1873
Welch, Harrisonafter June 16, 1868
Welch & Chipmanafter June 16, 1868
First & Pryibil (Steere example)after January, 1873
Pryibil (Poore example)after January, 1873
Pryibil (Barnhart example)after January, 1873
Collins & Greenwoodafter August 12, 1873
D.C. Allenafter May 26, 1874
First & Pryibil ('Woodshave' example)after 1876
D. C. AllenConcord NH
Collins & GreenwoodLebanon NH
C.B. Rogers & Co.Norwich CT
Welch & ChipmamSouth Boston MA
Welch, Harrison & Co.South Boston MA
First & Pryibil (2 examples)New York NY
Part 2. Patent Dates and other early band saws that are non four footed, but are cast iron and do not have fully cast iron wheels
The VintageMachinery.org archive as of this writing (November 20, 2006) lists thirteen (13) band saws thought to be relatively early produced examples that are not four footed, and are cast iron and, in general do not have fully cast iron wheels.
  • Atlantic Works (5 examples)
  • J.A. Fay & Co. (3 examples)
  • Goodell & Waters (2 examples)
  • L. Power & Co. (2 examples)
  • Baxter D. Whitney (1 example)
  • Atlantic Works (Hanson example) last date 1873
  • Atlantic Works (Potts example L.B & O) last date 1871
  • Atlantic Works (Streff example) no record of patent mark
  • Atlantic Works (Potts no. 2 example B & O) no record of patent mark
  • Atlantic Works (Gee example L.B. & O) last date 1871
  • J.A. Fay & Co. (Buck example) last date 1874
  • J.A. Fay & Co. (Haire example) last date 1874
  • J.A. Fay & Co. example? last date 1874
  • Goodell & Waters (Thomas example) no record of patent mark
  • Goodell & Waters (Fisher example) said to be 1882
  • L. Power & Co. (Bernstein example) no record of patent mark
  • L. Power & Co. (Potts example) no record of patent mark
  • Baxter D. Whitney no record of patent mark
  • J.A. Fay & Co. (as Page & Co.) 1834 (as J.A. Fay & Co.) prior to 1850
  • Baxter D. Whitney (circa 1837)
  • L. Power & Co. (circa 1867)
  • Goodell & Waters (as Goodell, Braun & Co.) prior to 1869 (as Goodell & Waters) circa 1873 or 1874
  • Atlantic Works (as Richards, Kelley, & Co.) 1870
Part 3. Comparison of earliest (i.e. not latest) patent dates of early band saws
J.A. Fay & Co. (Haire example)Reissued Aug. 25. 1865, Pat June 16.1868, Sept. 1. Nov. 1. 1871, May 21. 1872, May 19. 1874.
First & Pryibil ('Woodshave' example)said to be 1876 (prob '1866)
Pryibil (Poore example)'Pat Aug 28 1866 & Jan 73'
Pryibil (Barnhart example)'Pat 1866 & 73'
Welch, HarrisonJune 16, 1868
Welch & ChipmamJune 16, 1868
J.A. Fay & Co. (Buck example)June 16, 1868, Sept 19, 1871, Nov. 14, 1871, May 21, 1872, May 19,1874
First & Pryibil (Steere example)Aug 28, 1868 & Jan 1873
Atlantic Works (Potts example L.B & O)June 7, 1870, Jun. 28, 1870, Apr. 25, 1871, May 9, 1871
Atlantic Works (Gee example)June 7, 1870, June 28 1870, April 25, 1871, May 9, 1871
Atlantic Works (Hanson example)June 7, 1870, June 28 1870, April 25, 1871, May 9, 1871
J.A. Fay & Co. (? example)May 19, 1874 (only date recorded may be others?)
Goodell & Waters (Fisher example)said to be 1882
  • Reissued Aug. 25. 1865
  • Pat June16, 1868,
  • Sept. 1 Nov. 1 1871,
  • May 21, 1872,
  • May 19, 1874.
Reissued Aug. 25. 1865no J.A. Fay & Co patent this date
Pat June16, 1868Improvement in guides for bandsaws
Sept. 1 Nov. 1 1871no J.A. Fay & Co patent these dates
May 21, 1872Improvement in pulleys for bandsaws
May 19, 1874Improvement in band sawing machines
Part 4. Comparison of patent dates between four footed cast iron, cast iron wheeled band saws and early band saws that are not four footed, are cast iron with, generally, non-cast iron wheels
(I do have a photograph in my records of an interesting Goodell & Waters band saw—one of the few that have a combination flanged base / cored frame construction, as does the Goodell & Waters band saw archived on VintageMachinery.org with the questionable patent date. This saw—the one in my archives not the one in the VintageMachinery listings - has a serial number of 6109 (or 8109, this is not clear) and a patent date of September 4th, 1883—which is correct - and also featured wood-rimmed wheels and an unusual spoke construction—probably steel with a cast iron hub. The Goodell & Waters saw with the questionable patent date has more regular wood-rimmed top wheel and is listed as a 'model 3.')
Jun. 16, 1868J.A. FayJohn Lemman
Jun. 28, 1870 Atlantic Works William H. Thorne
1837Baxter D. Whitney
1847 J.A. Fay
1867 L. Power
c. 1869 Goodell & Waters
c. 1869 Atlantic Works
