Patching sheet metal holes using low temp solder.
RSS
Modified on 2023/01/21 11:04 by Jeff Joslin Categorized as Restoration Topics
Original article by "goosewing" (Gary McHugh)
before and after
before and after
Getting Started
holes to be patched
Prep
stripped and cleaned
A filler for the holes is needed, I used some soft copper from a pipe hanging fixture, hammered flat it was a perfect thickness for this application. For thicker sheet metal, an old copper penny might be a quick source of material. Using lineman's pliers, the plug is cut to shape, slowly snipping into a circle. When I got to where it fit, I pressed it into the hole using the same pliers.
plug pressed in place
Soldering
soldered
backside
Filing and Sanding
dressing down
The finished product
finished left and right
finished front
finished back
Remember:
Do all metal hammering and straightening first.
Clean area well.
Addendum:
Just a couple quick notes on soldering. Heating time will vary quite a bit depending on material thickness. I was soldering some 11 gauge sheet steel (0.1250"), and it took about 2 minutes of heat before the solder would flow. That's about as thick as you'll probably find (1/8" thick !), by comparison a Unisaw cabinet is 14 gauge, about 0.08 inches thickness.
When filling thick sheet metal like that I let the copper plug stay a little proud on the show side and dressed it down, the back side I filled with polyester filler (Bondo.)
And, as it deserves repeating, I can not over-emphasize the importance of cleaning the sheet metal thoroughly before soldering. Every time I've found myself hurrying and doing a cursory job I end up with solder not sticking and rolling off, wasting both time and material and making myself feel foolish. Bring the area to a bright shine with sandpaper, wire brush, emery cloth, whatever floats your boat.
