Main Page
Modified on 2026/06/01 15:13 by toolguybak — Categorized as: Engineering
Welcome to VintageMachinery.org Knowledge Base (Wiki)!
The VM Knowledge Base is a wiki based tool for topics related to the use and restoration of vintage metalworking & woodworking machinery, electric motors & controls, and steam & gas engines. Feel free to learn something as well as contribute to our knowledge base.
Any problems or bugs with this Knowledge Base can be reported to the
VM Webmaster
1 - VM Information
This section contains basic information about the VM web site and the OWWM forums.
A Short History of OWWM & VM
What do all of these sayings mean?
VM Member e-Bay Handles
Wiki Basics (or What's all this, then?)
2 - Restoration Topics
The following topics will cover machinery restoration
2.1 - Bandsaws
Fine-Tuning a Bandsaw
(article by Bob Vaughan)
Bandsaw Blade Lengths
Bandsaw Blade Soldering
Homebuilt Ball Bearing Bandsaw Guides
One method for balancing band saw wheels
Restoring a Crescent 36" Band Saw
Part 1 - Tear down and clean up
Part 3 - Finishing Up
Tire Crowning
Bandsaw Throat Plate Table Insert Measurements and Dimensions
2.2 - Bearings, Babbitt
Introduction to Babbitt Bearings
What is Babbitt?
Where to buy Babbitt?
Babbitt Identification Guide
Babbitt Pouring Supplies
Lubrication Systems for Babbitt
Pouring High Speed Bearings
Pouring Babbitt Bearings on a Crescent Band Saw
Some Babbitting Suggestions
- Reprinted from the Nov. 1924 issue of
The Wood-Worker
The Application of Babbitt Metals (pdf) (1921)
Something About Oil Grooves
2.3 - Bearings, Ball & Bronze
Ball Bearing Primer
Ball Bear Revival
Removing Difficult Bearings
Replacement Bearing List
Replacement Bearing List - Craftsman Companion Dunlap Sears Machines
2.4 - Decal Reproductions
Whether you call them decals, badges, or nameplates, we have instructions on creating them plus a library of artwork that you can use.
Creating Decals
A collection of artwork to reproduce decals from for OWWM restorations
2.5 - Drill Presses
Restoring a Canedy-Otto New No. 16 info from Peter Sarafan (pdf)
General drill chuck and Delta drill press info from Bob Vaughan (pdf)
Drill press tune-up article by Bob Vaughan (pdf)
Jacobs Chuck Repair Guide (pdf)
Jacobs Precision Chuck Repair Guide (pdf)
Jacobs Chuck Technical Information (pdf)
Pressing a Drill Press base off of a column
Rebuilding a Jacobs Chuck
Changing the Belt on a Walker-Turner 900 Drill Press
Sharpening Drill Bits (pdf)
2.6 - General Maintenance
Yearly Maintenance Checklist
Tips and Tricks
2.7 - General Reference
Dimensions of Standard Tapers
Understanding Scotch-Brite and other abrasives
(PDF; contributed by Matthew A.)
2.8 - Jointers and Planers
How To Tune A Jointer
Jointer and Planer Knife Setting Videos
Jointer and Planer Knife Sharpening Services
Jointer and Planer Knife Sizes
Getting Peak Planer Performance
In-place Planer Knife Grinding and Jointing
Jointer Clamshell Heads
Grinding Jointer Tables
Craftsman/Companion/Dunlap/Sears Jointer and Planer Knives
Replacing bearings and roller on Belsaw 910 planer
2.9 - Line Shafts and Flat Belts
How To Make Leather Belts
Lacing Leather Belts
Leather Belting FAQ
2.10 - Lubrication
Grease and Lubrication
Bearing Grease Life
2.11 - Restoration Tips
Creating Decals
Fabricating Knobs and Levers
High Quality Brush Painting
Metal Plating
Buffing Parts Before Plating
Bench Top Plating
Paint Colors
A Basic Machinery Restoration Guide
Rust Removal By Electrolysis
Patching sheet metal holes using low temp solder
Grinding Guide
Repainting Badges and Tags
Flattening Cast Iron Surfaces
Scored Shaft Repair
Fixing a Dead Switch
"Good Looking Tools", a Eagle Paint and Varnish Co. pamphlet
Step pulley repair
2.12 - Sanders
Belt Sanders (Delta 6x48)
2.13 - Scroll / Jig Saws
Scroll Saw Air Pump Rebuild
Rebuilding a jigsaw sawdust blower
Sears Scroll Saw Crankcase Lubrication Summary
6-Inch Scroll Saw Blade Sources
Delta Homecraft 40-110 Scroll Saw Crankcase Gasket Template
Delta 40-440 scroll saw spring replacements
2.14 - Sources
Foundry Sources
Part Sources
— general supplies and machine-specific parts for a wide range of makers
2.15 - Tablesaws
Rip Fence Review
Circular saw blade bushings
3 - Manufacturer Specific Information
This section will contain information specific to a manufacturer
3.1 - American Wood Working Machine Co.
Machine Models and Plant History for AWWM
3.2 - Atlas Press Co
Atlas Press Co. Paint Colors
Atlas 6050 Jointer Porkchop Tracing, Download PDF
Atlas V-Belt Part Number to Length Cross-Reference
3.3 - W. F. & John Barnes Company
History of the W. F. & John Barnes Company
3.35 - Black & Decker Corp.
Electric Drill Restoration
3.4 - Boice-Crane
Boice-Crane 6" Jointer (Model 1400) Replacement Lock
Boice-Crane Oscilling Spindle Sander Bearing Replacement
3.5 - Buffalo Forge
Buffalo Forge History
3.6 - Canedy-Otto Manufacturing Co.
3.7 - Craftsman/Companion/Dunlap (and other Sears brands)
Craftsman Paint Colors
Ted Duncan's article, "1935 Craftsman drill presses made by Walker-Turner: research and type study" (PDF)
3.8 - Crescent Machine Company
History of the Crescent Machine Company
Crescent Serial Numbers
Crescent Machine Company General Timeline
Crescent Jointer Type Study
Crescent Jointer Guard
A 4-inch Crescent Jointer from 1918, article by Scott Crosby
Brief catalog study of Crescent iron C frame 20" band saws
Crescent Paint Colors
See also- Delta 12-14 Table Saw
3.9 - Dayton
Dayton Bench Grinder Wiring
3.10 - Delta
3.10.1 - General Information
Delta Serial Numbers
History of Delta Machine Models
History of Rockwell-Delta in South Africa
Delta Cast Iron Stand Study
Delta Push-Pull Rod Switch Bracket
Delta Paint Colors
Motor Plate Tracings
Delta Reproduction Parts
Delta Open Stands (pdf)
Delta/Rockwell Wiring Diagrams
Weights of various Delta machines and motors
3.10.2 - Delta Bandsaws
Delta 14" Bandsaw Type Study
Delta 14" Wood/Metal Bandsaw Gearing
3.10.3 - Delta Drill Presses
3.10.4 - Delta Lathes
Assembling a Delta Compound Slide Rest
3.10.5 - Delta Sanders
Delta 6" (6x48) Belt Sander
3.10.6 - Delta 12-14" Table Saw
Replacing Arbor Bearings on the Delta 12-14" Saw
Grizzly Parts That Will Fit the Delta 12-14 Saw
Making A New Arbor For A Delta/Crescent 12-14 Saw
3.10.7 - Delta Unisaw
Unisaw Type Study
Unisaw RI Bullet Motor
Unisaw Bullet Motor Repair
Alternate Motor Mounts For Your Unisaw
Unisaw Disassembly
How to Properly Disassemble and Clean a Unisaw
Unisaw Replacement Belts
3.10.8 - Delta Radial Arm Saw
3.10.9 - Delta Planer
Dan Swartz article on Rebuilding a 22-101 Planer
3.11 - DeWalt
DeWalt MBF & MBC Motor Bearing Replacement
DeWalt MBF & MBC Rollerhead Bearing Replacement
DeWalt Frame 236 Motor Bearing Replacement
3.12 - Greenerd
Arbor Plate Drawings for a Greenerd No. 2 Press
3.13 - J. A. Fay & Egan Co.
J. A. Fay and Egan Company History
3.14 - Kneisley Electric Company
A Brief History of Yager/K2000 Planers
K-Line K2100 planer
K-Line K2200 planer
Yager Thickness Planer parts and dismantling
Setting knives for a square cutterhead Yager
Another knife setting method
A rare geared power feed option
3.15 - KTS Industries
History of KTS Industries, Inc.
3.16 - Millbury Machine Co.
Sharpening Millbury Tenoner Cutters
3.17 - Montgomery Ward
3.18 - Newman
Newman History
Newman Serial Numbers
3.19 - Northfield
Northfield Serial Numbers
Northfield #4 Table Saw Restoration Threads / Links
Northfield Paint Colors
3.20 - Oliver
Early History of the Oliver Machinery Company
A Brief history of the Oliver Machinery Company
Oliver Machinery Co. Catalog Study
Oliver Early Serial Numbers
Oliver Serial Numbers
Oliver Paint Colors
Oliver Shaper Spindle Removal
3.21 Thomas Robinson & Son
History of Thomas Robinson & Son
3.22 - Parks
Guide To Buying A Parks Planer
Parks Paint Colors
Parks Heavy Duty 12" x 4" Planer
Parks Planer Settings
Notes on Dating a Parks Planer
Parks History
Parks 12" Planer Parts and Photo Index
Restoring a Parks Planer
3.23 - Powermatic
Powermatic 66 PM66 PM 66 Table Saw Tablesaw Restoration Threads on OWWM
PM 1150 Drill Press Bearing Replacement Guide
PM 1150A VS bearings and spindle
Rebuilding a PM 45 Wood Lathe
Powermatic Paint Colors
Powermatic Serial Numbers
3.24 - Shopsmith
Buying a used Shopsmith Mark V
anchor
3.25 - South Bend Lathe Works
South Bend Lathe Works serial numbers
3.26 - Sprunger
Sprunger History
3.27 - Tannewitz
Tannewitz serial numbers
3.28 - Walker-Turner
Driver Line Motor Wiring Diagram
Walker-Turner General Timeline
Walker-Turner Paint Colors
Walker-Turner Serial Numbers
Walker-Turner Bandsaw Table Tilt Bracket Reproduction
Walker-Turner 16" Bandsaw Blade Guard drawings
Walker-Turner L1152 Lathe Parts Breakdown
3.29 - West Side Iron Works (J. Jackoboice)
West Side Iron Works, Complete History
(pdf)
3.30 - Whitney Baxter D.
Baxter D. Whitney History
Whitney Serial Numbers
3.31 - Yates American
J180 Planer - Collection of Restoration Videos by Paul Novelli:
J180 Video Playlist on YouTube
B244 30" Planer - Collection of Restoration Videos by Paul Novelli:
B244 30" Video Playlist on YouTube
4 - Electrical
This section contains information on electrical topics
Electrical Power Cord Type Designations
4.1 - Motor Information
Electric Motor Types (1921)
Electric Motor Tutorial (1940)
Farm Motors-Electric Motors (1917)
Typical single phase motor wiring
Baldor Motor Repair
Century manual for single-phase motors
(ca. 1928, 3.8 MB PDF)
Motors for Your Vintage Machinery
—Horse power; troubleshooting induction motors; motor frame sizes
List of Motor Manufacturers
Power Factor in Alternating Current Circuits
Wagner Electric - Capacitor Start Motor Service Instructions
(1947, 3.4 MB PDF)
Wagner Electric - Repulsion Start Motor Service Instructions
(1942, 4.4 MB PDF)
4.2 - Magnetic Starter Information
Magnetic Starters: A Tutorial
Motor Starter Wiring Diagrams
Furnas Magnetic Starter Control Cleaning
Mag Starter Hum
4.3 - Three Phase Information
Three Phase Frequently Asked Questions
VFD Frequent Questions
4.4 - Overload Protection Information
Allen Bradley Overload Protection Chart
(pdf)
Klixon Phenolic Motor Protectors (pdf)
4.5 - Rotary Phase Converters
Intro
RPC construction methods
5 - Frequently Asked Questions at Vintage Machinery
Buying and Selling Machinery and Machine Parts
How Much Is My Machine Worth?
Our Mission
OWWM.org vs Vintagemachinery.org
Photo & Publication Submissions
Registry Stewards
User Name & Password
Using the Search Box in VM
Where Can I Find Old Manuals and other "Dirty Paper"?
6 - Biographies & Obituaries
Abell, John, Obituary (1903)
Baldwin, Matthias W. (1921)
Bancroft, John Sellers (1919)
Barnes, Benjamin Franklin (1919)
Bement, William B. (1895)
Blanchard, Thomas (1906)
Blandy, F. J. L. (1875)
Blandy, H. (1875)
Bovaird, David (1890)
Bradley, Christopher C. (1916)
Brown, George W. (1896)
Bullard, Edward P., Sr. (1907)
Burdict, Orrin C. (1905)
Charter, John, Sr., Obituary (1901)
Corliss, George Henry (1888)
Cordesman, H. J., Sr. (1919)
Davis, Aaron (1857)
Disston, Henry, Obituary (1890)
Doane, William H. (1998, PDF)
Eames, Lovett and Eames, Gardner T. (1904)
Egan, Thomas P. (1922)
Evans, Oliver (1906)
Farrar, Chilion M., Obituary (1907)
Gates, Philetus Woodworth (1921)
Greenleaf, Clements A. (1893)
Hoard, Charles B. (1895)
Huber, Edward (1904)
Johansson, Carl Edvard (1924)
Joslin, Edward (1901)
Kearney, Edward J. (1922)
Kelly, Oliver Smith (1918)
Leffel, James (1875)
Medart, Philip (1899)
Medart, William (1899)
Mills, James (1913)
Muir, William (1888)
Napier, Charles (1918)
Newton, Charles C. (1906)
Oesterlein, William (Wilhelm) (1920)
Prescott, DeWitt Clinton (1920)
Reed, Joseph B. (1912)
Root, Elisha K. (1866 & 1916)
Rumely, Meinrad (1904)
Shepard, Sidney(1894)
Schauer, Sherman Cornelius (1918)
Sembower, Guy Knowlton (1925)
Seyfang, John L. (1890)
Slate, Dwight (1906)
Sweet, John E. (1917)
Skinner, LeGrand (1922)
Sweet, John E. Obituary (1916)
Trecker, Theodore (1922)
Trefts, John (1898)
Trefts, George M. (1898)
Weiss, Carl W. (1918)
Westinghouse, George (1914)
Whitney, Amos, Obituary (1920)
Woods, Solomon A. Obituary (1910)
7 - Gas Engines
A Brief History of the Internal Combustion Engine (1914)
Farm Motors-Gas and Oil Engines (1917)
Modern Gas and Oil Engines (Part 1)(1893)
Modern Gas and Oil Engines (Part 2)(1893)
Modern Gas and Oil Engines (Part 3)(1893)
Modern Gas and Oil Engines (Part 4)(1893)
Modern Gas and Oil Engines (Part 5)(1893)
Modern Gas and Oil Engines (Part 6)(1893)
Modern Gas and Oil Engines (Part 7)(1893)
Modern Gas and Oil Engines (Part 8)(1893)
The Modern Gas Engine (1895)
Various Types of Engines and Motors (Part 1)(1898)
Various Types of Engines and Motors (Part 2)(1898)
Various Types of Engines and Motors (Part 3)(1898)
8 - Gas Traction Engines
Farm Motors-Gas Traction Engines (1917)
9 - Metalworking Machinery
American Standard Lathe Spindle Nose Dimensions
Leveling a Machine
Metalworking Machinery Serial Numbers
History of Metalworking Machines (1890)
Development of the Turret Lathe (1900)
Milling Machine Dividing Heads (1902)
Milling Machines in the United States (1902)
Power Hammers and Their Uses (1908)
Principles of Tool Room Grinding
(pdf) (1944)
Techinical Manual-Lathes Part 1
(pdf) (1940)
Techinical Manual-Lathes Part 2
(pdf) (1940)
Treatise on the Heavy Milling Machines (1903)
Treatise on the Plano Millers (1903)
Standard Planer & Parting Tools
===10 - Publication Reprints===
11 - Sawmills
Small Sawmill Operator's Manual
(pdf) (1958)
11 - Steam Engines
Steam Engines at the World’s Fair (Parts 1-2) (1893)
Steam Engines at the World’s Fair (Parts 3-4) (1893)
Steam Engine Frequently Asked Questions (1902)
Early American High Speed Engines (1903)
Early History of the Steam Engine (1902)
Historical Sketch of the Steam Engine (1908)
Production Figures for Agricultural Steam Engines (1953)
The History of the Steam Engine (1890)
Steam Engine Foundations (1902)
Steam Engine Parts (1902)
Materials and Workmanship of the Steam Engine (1902)
Care and Management of the Steam Engine (1902)
Farm Motors-Stationary Steam Engines (1917)
12 - Steam Traction Engines
Development of the Steam Traction Engine in America (Part 1) (Aug. 1916)
Development of the Steam Traction Engine in America (Part 2) (Oct. 1916)
General Description of Traction Engines (1908)
Farm Motors-Steam Traction Engines (1917)
Modern English Traction Engines (1896)
Steam Traction Engine Manufacturers
The Thresher’s (Steam Traction Engine) Guide, Volume 1, Foreword & Table of Contents (1910)
The Thresher’s (Steam Traction Engine) Guide, Volume 1, Chapter 1 (1910)
The Thresher’s (Steam Traction Engine) Guide, Volume 1, Chapter 2 (1910)
The Thresher’s (Steam Traction Engine) Guide, Volume 1, Chapter 3 (1910)
The Thresher’s (Steam Traction Engine) Guide, Volume 1, Chapter 4 (1910)
The Thresher’s (Steam Traction Engine) Guide, Volume 1, Chapter 5 (1910)
The Thresher’s (Steam Traction Engine) Guide, Volume 1, Chapter 6 (1910)
The Thresher’s (Steam Traction Engine) Guide, Volume 1, Chapter 7 (1910)
The Thresher’s (Steam Traction Engine) Guide, Volume 1, Chapter 8 (1910)
The Thresher’s (Steam Traction Engine) Guide, Volume 1, Chapter 9 (1910)
The Thresher’s (Steam Traction Engine) Guide, Volume 1, Chapter 10 (1910)
13 - Videos
Videos from the Georgia Agrirama
Yates J180 Planer - Collection of Restoration Videos by Paul Novelli on YouTube
14 - Woodworking Machinery History
Band Saw History
Pre History of Band Saws
Early History of Band Saws
Jointer History
Pre History of Jointers
Early History of Jointers
Lathe History
History of Lathes (1900)
Radial Arm Saw History
Pre History of Radial Arm Saws
Early History of Radial Arm Saws
Table Saw History
Origins Of Two Bladed Table Saws
Early History of Wood-Working Machines (1870)
Histories of Woodworking Machinery
